Dyno of S2Karts Modded Greddy
Originally Posted by smirfs2k05,Feb 17 2008, 12:35 PM
Not knocking your car or anything but say your car is tuned for meth..what are you going to do when you run out of meth?..ecu can't compensate for the lack of meth..just a thought
Originally Posted by otbs2k,Feb 19 2008, 02:45 AM
There are plenty of options available to ensure that you're either made aware that the methanol is low or the flow has a blockage, along with plenty of options that ensure you return to wastegate boost levels or lower levels of timing. I had methanol injection on my EVO and it was fantastic... sure as hell beats putting race gas in everytime you want to turn up the boost and it's a lot cheaper. A gallon of methanol lasted me over a month constantly. It's just like checking your oil when you get gas, you check the methanol... it doesn't take a genius. Methanol injection will be going into the S2000 as well. I can't sing it's praises enough. Do some research before you ask a somewhat pointless question and clog up a useful thread.
While the water/meth mist cools the intake air ALOT, the main benefit is what happens in the combustion chamber, sucking up heat as the water converts to steam.
vbb
Apr 9, 2012 09:50 AM
tlmg21700
May 11, 2010 08:18 PM
