E85 + Stock Lines and Max WHP
Old Dec 10, 2012 | 08:43 PM
  #21
Phill24's Avatar
Inline filters are good for ppl running the pumps outside of the tank meaning some 1 with a sumpted tank... The internal filters work fine
  #22
sohc_mshue's Avatar
515whp dynojet here on e85 with stock lines running an in tank walbro 400. I could probably push a bit more, but fuel pressure drops about 10psi by redline.
Old Dec 10, 2012 | 08:45 PM
  #23
bobbyrandolph440's Avatar
Just dont.want.to have to clean the in tank alot
Sent from my DROID RAZR using Tapatalk 2
Old Dec 10, 2012 | 08:46 PM
  #24
neeman77's Avatar
I was maxing out 2000cc injectors at 45 psi base pressure with dual 255's on -8AN feed -6AN drain at 816hp using E85. Since you have 340s but will be on stock lines I would say somewhere around 750-800 as well like g352s2k said.
Old Dec 10, 2012 | 09:01 PM
  #25
Im running.l twin340s -10 feed and -6 return and.2000cc injectors what power mine good.for at 55psi
Old Dec 11, 2012 | 05:50 AM
  #26
1SlowSi's Avatar
Joey I would go ahead and just run your own lines man. Why skimp out on something so little and so cheap. I went on Jegs and ordered all the line and fittings for maybe $150.
Old Dec 11, 2012 | 06:41 AM
  #27
spectacle's Avatar
You call that cheap? Stock lines are free y0
Old Dec 11, 2012 | 09:15 AM
  #28
neeman77's Avatar
I would think somewhere around 950-1000 hp but that's uncharted territory for me.
Old Dec 11, 2012 | 09:26 AM
  #29
passmans2kny's Avatar
55 psi? dam I'd say that would be 1100 hp territory
Old Dec 11, 2012 | 10:17 AM
  #30
spectacle's Avatar
I think he meant 55psi base fuel pressure.
