e85 supporting mods for boost
Old Jun 21, 2019 | 07:09 PM
landapanda's Avatar
Default e85 supporting mods for boost
I bought a used Greddy kit and I want to squeeze as much as I can out of it reliably. I put together list of supporting mods and want advice whether they are well chosen parts to support flex fuel setup. Still havent decided on the ECU (Infinity or AEM v2). The kit came with: the greddy turbo, pfab manifold, hot/cold side piping, intercooler, BOV, Wastegate, Downpipe and oil relocation.
-Injectors - 1050Xcc ID: https://www.realstreetperformance.co...05-11mm-2.html
-GM Flex Fuel Sensor:
https://www.amazon.com/ACDelco-13507128-Original-Equipment-Sensor/dp/B073ZQ1G2P/ref=asc_df_B073ZQ1G2P/?tag=hyprod-20&linkCode=df0&hvadid=312373636797&hvpos=1o1&hvnetw=g&hvrand=5578378046250619547&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9031627&hvtargid=pla-568841504762&psc=1 https://www.amazon.com/ACDelco-13507128-Original-Equipment-Sensor/dp/B073ZQ1G2P/ref=asc_df_B073ZQ1G2P/?tag=hyprod-20&linkCode=df0&hvadid=312373636797&hvpos=1o1&hvnetw=g&hvrand=5578378046250619547&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9031627&hvtargid=pla-568841504762&psc=1
-Fuel Line Quick Disconnect 3/8" Steel to 5/16" Nylon Tubing: https://www.dormanproducts.com/itemd...EName=800-0855
-E85 Flex Fuel Sensor Connector Pigtail Plastic Fuel Composition Ethanol-
https://www.amazon.com/Connector-Pigtail-Plastic-Composition-Ethanol/dp/B07115TSNK/ref=pd_bxgy_263_img_2/147-1252377-4386567?_encoding=UTF8&pd_rd_i=B07115TSNK&pd_rd_r=9a04d268-9481-11e9-86a8-c5ace3dfaeef&pd_rd_w=0kdD0&pd_rd_wg=ckK3v&pf_rd_p=a2006322-0bc0-4db9-a08e-d168c18ce6f0&pf_rd_r=K0DD0E4KZSRAB2PTTA2T&psc=1&refRID=K0DD0E4KZSRAB2PTTA2T https://www.amazon.com/Connector-Pigtail-Plastic-Composition-Ethanol/dp/B07115TSNK/ref=pd_bxgy_263_img_2/147-1252377-4386567?_encoding=UTF8&pd_rd_i=B07115TSNK&pd_rd_r=9a04d268-9481-11e9-86a8-c5ace3dfaeef&pd_rd_w=0kdD0&pd_rd_wg=ckK3v&pf_rd_p=a2006322-0bc0-4db9-a08e-d168c18ce6f0&pf_rd_r=K0DD0E4KZSRAB2PTTA2T&psc=1&refRID=K0DD0E4KZSRAB2PTTA2T
-E85 Content Analyzer: Zeitronix ECA : SEMA Award Winning Ethanol Content Analyzer and Flex Fuel Sensor for E-85 and E-85/gasoline Blends
-Aeromotive 340 lph Fuel Pump: Aeromotive - Aeromotive 11142 s2000 Fuel Pump #AEO11142
Old Jun 21, 2019 | 10:10 PM
umair's Avatar
I have an aem EMS v2 that I'll sell you for dirt cheap along with some injectors. PM me if you are interested.
Old Jun 22, 2019 | 07:08 AM
bruthaboost's Avatar
If you get the infinity, you won't need zeittronix unit. I'd recommend the gaugeart multiguage that will display everything.
Old Jun 22, 2019 | 07:22 AM
Charper732's Avatar
I 2nd this. But AEM has a gauge called AEMNET that is less than half the cost of the gauge art and allows you to cycle through whatever information you're trying to see.
Old Jun 22, 2019 | 10:57 AM
jdmz's Avatar
I would seriously consider a larger injector for E85. I ran out of fuel on my ID1000's at 14 psi. Get 1300cc or 1650cc. Also recommend a Walbro 450 or Walbro 525.
Also, a fuel pressure sensor when going AEM Infinity is a must! The Clean Injection sensor from eBay worked well for me: https://www.ebay.com/itm/182811951850
For tuner, I highly recommend Jeff Evans for a flex fuel eTune if you don't have a local tuner you trust. He has high attention to detail and won't hesitate to help you if you run into issues. He also has a great price for a flex fuel tune.
Old Jun 22, 2019 | 06:20 PM
AP1Chief's Avatar
IF you go aem EMS V2 and I can get you all fixed up on a great tune look at my reviews on here
Old Jun 23, 2019 | 10:30 AM
landapanda's Avatar
Does larger injectors and pump affect the tune at all for a small turbo? So If I wanted to upgrade down the road I’d have all those supporting mods.
Added fuel pressure sensor to the list. Appreciated!
Old Jun 23, 2019 | 10:43 AM
landapanda's Avatar
Perfect that’s the one gauge I really needed.
Old Jun 23, 2019 | 07:21 PM
jdmz's Avatar
You will need an adjustable fuel pressure regulator to lower your pressure with the walbro 450. I was pinned at 76 psi or so with the stock Fpr.
The 1300cc injectors idle better than my Id1000... I got the fuel injection connection injectors for less than $500 on memorial day. Their calibration data was way off though but my tuner sorted it out.
Not sure if the aem V2 does the same thing but my infinity compensates for fuel pressure changes so I could adjust the fuel pressure without affecting my tune. It's really nice and adds another level of protection for your engine.
Old Jun 25, 2019 | 05:25 PM
landapanda's Avatar
Yeah I figured I would need the afr with a 450 fuel pump. Does the stock fuel rail hold up well to everything else?
Good thing I picked up an infinity yesterday for a decent deal haha. I'll make sure to find a tuner who knows infinity well and can make that fuel pressure readings stable.
