E85 vs. Methanol Injection
Old Dec 24, 2010 | 07:24 AM
  #31
DFWs2k's Avatar
so using meth doesn't contaminate your oil quicker? how often do you have to change your oil if using e85?
Old Dec 24, 2010 | 08:00 AM
  #32
boostedf22c's Avatar
I didn't notice any contamination using the water/meth kit.
You are only using an injector the equivalent of a 550cc injector, and 1/2 with meth, and 1/2 with water.
With E85 you are injecting SO MUCH MORE into the motor, and it WILL contaminate the oil quicker.
I always change the oil in any of my high performance cars about ever 1000 miles.
So if you are asking if using a water/meth injection system contaminates your oil quicker than using E85, the answer is no.
Old Dec 24, 2010 | 09:58 AM
  #33
DFWs2k's Avatar
i meant more contamination with water/meth and pump over just pump, sounds like it'd be negligible
Old Dec 24, 2010 | 10:05 AM
  #34
Possibly, but like I said, I change my oil every 1000 miles. So in that 1000 miles I didn't notice anything.
For me, if I need more than a water/meth kit allows, I'll go to race fuel from here on out. The fact that I was able to make over 700whp, drive the car everyday, run 9's and get over 20mpg all while having no motor problems makes me happy.
That said, E85 isn't a substitute for race fuel, and neither is water/meth. They are both alternatives to straight pump gas.
Old Dec 24, 2010 | 11:49 AM
  #35
iApex's Avatar
Originally Posted by siadam,Dec 23 2010, 06:24 PM
650whp & 25psi+
When I pulled the motor, you could see the effects. Each cylinder was progressively worse.
Old Dec 24, 2010 | 02:21 PM
  #36
DFWs2k's Avatar
Originally Posted by siadam,Dec 23 2010, 08:24 PM
650whp & 25psi+
was yours spraying all the time?
I wanted something safe to 550whp or so, but I know I wouldn't be able to change my oil every 1k miles. I don't get on it very often, so maybe I can just have my tuner set up to spray meth over 15 psi or something? just trying to figure out a safe way.
It'd cost more to convert to go to e85 than to get a direct port water/meth system set up, from what i'm seeing.
Old Dec 24, 2010 | 04:41 PM
  #37
s2kadrenalin's Avatar
I don't see the benefits of E85 or Meth when you consider MS109 or C16 instead.
Old Dec 24, 2010 | 05:36 PM
  #38
DFWs2k's Avatar
meth and e85 are a lot cheaper and easier to come by
Old Dec 24, 2010 | 08:21 PM
  #39
D1sclaimer's Avatar
The title of the thread is "E85 vs. Methanol Injection."
Old Dec 24, 2010 | 09:45 PM
  #40
EternalLx's Avatar
S2000junky how offen to you change your oil?
