E85 vs. Methanol Injection
Old Dec 28, 2010 | 10:21 AM
  #51
itlynstalyn's Avatar
Does the power level really make a difference on which to use? I'm only going to be about 350rwhp at around 10-13 psi.
Old Dec 28, 2010 | 12:09 PM
  #52
neeman77's Avatar
Why not just run pump gas?
Old Dec 28, 2010 | 04:01 PM
  #53
Because the 91 octane in california is shit.
Old Dec 28, 2010 | 04:15 PM
  #54
s2000Junky's Avatar
Your a prime candidate for a water/meth kit. No sense in using e85 for your power level. Water/meth benefits you at any psi level, whether it be keeping your intake and combustion temps cool to near N/A temps depending on your water ratio, steam cleaning your top end keeping your intake and valves, piston tops pristine clean and performing like new, or giving you that added margin of safety in hard driving environments such as racing. E85 doesn't really do any of these things.
Old Dec 29, 2010 | 11:13 AM
  #55
D1sclaimer's Avatar
[QUOTE=s2000Junky,Dec 28 2010, 07:15 PM] Your a prime candidate for a water/meth kit. No sense in using e85 for your power level. Water/meth benefits you at any psi level, whether it be keeping your intake and combustion temps cool to near N/A temps depending on your water ratio, steam cleaning your top end keeping your intake and valves, piston tops pristine clean and performing like new, or giving you that added margin of safety in hard driving environments such as racing.
Old Dec 29, 2010 | 12:28 PM
  #56
Deception's Avatar
Originally Posted by D1sclaimer,Dec 29 2010, 03:13 PM
Are any water/meth kits CARB legal?
just tell them its an upgraded washer fluid system
Old Dec 29, 2010 | 03:31 PM
  #57
s2000Junky's Avatar
Yeah, just plumbed into your motor lol. Its the same fluid. You could literally tap a separate line from your factory washer fluid tank and run both at the same time if you wanted
Deception
Jun 17, 2011 05:54 PM
dsddcd
May 17, 2009 08:00 PM
chimmike
Dec 30, 2008 03:13 PM
Xherrox
Dec 12, 2008 03:06 PM
nightcrawler7188
Jan 29, 2008 04:40 PM
