The Effects of Changing Mounts on Manifold Longevity
Old May 21, 2012 | 10:03 AM
redboost10's Avatar
Correctly built tube manifold will outlast a pipe manifold in any circumstance due to bring able to withstand more vibrations
Old May 21, 2012 | 10:29 AM
herecomesboost's Avatar
For the unfamiliar, what's the difference between tube and pipe manifolds?
Old May 21, 2012 | 10:56 AM
redboost10's Avatar
Pipe is rated in schedule and weighs a ton.
Tubing is rated in gauge and is more vibration resistant.
Difference is a lot of weight savings with tubing.
Old May 21, 2012 | 11:10 AM
spectacle's Avatar
I'll go into details later, but for now I'll just say this - stiff motor mounts and sidewinders do not mix.
Old May 21, 2012 | 11:22 AM
I've read your build threads (feel free to relay details in this thread ). I also have a Mase manifold (bought it second hand; no cracks from the previous owner). Was your cracking issue directly related to the stiff mounts?
Old May 21, 2012 | 01:35 PM
DFWs2k's Avatar
Many mase manifold owners with stock mounts also experienced cracking.
Sent using free Tapatalk - Android FTW
Old May 21, 2012 | 01:47 PM
Due to a design flaw associated with the manifold?
Old May 21, 2012 | 04:23 PM
05TurboS2k's Avatar
Originally Posted by illestrolla
I have also pondered this.
I can't imagine anything can be worse than broken stock mounts as the excess movement is translated down your exhaust, and torques on the mani.
Flex-less downpipes crack manifolds almost instantly.
I don't see why stiff mounts and a nice flex section would be any worse. Certainly interested to hear what others have to say.
Exactly my thoughts as I have one torn right now. I would expect stiffer to be better for exactly the reason you mentioned. I'd change only the passenger side if it was me as the other rubber side would allow for vibrations to be soaked up. Also I suppose should consider motor rotation direction though. Something to weigh out.
With a flex section in the pipe I would imagine the harsher vibrations are worse if anything but this is simply a guess on my part. If one has stock mounts I'd strongly urge them to get a flex section if they're on a tubular.
Old May 21, 2012 | 05:04 PM
redboost10's Avatar
Rod ends are your friend with tubular manifolds. Never have had a problem. Gotta anticipate the direction of the expansion when bracing
zaff
Dec 1, 2012 09:51 AM
MegaTRon
Jan 6, 2012 07:51 AM
