EGT Guage question
Old Jun 28, 2010 | 11:08 AM
boostedf22c's Avatar
If you are just going to install one, install it in cylinder # 1 a couple of inches from the port.
This is the known cylinder that will typically go leaner.
Use a bunch of grease on the drill and tap (to catch the majority of the shavings) and you'll be ok. I did mine with my manifold on and turbo and everything in place with no issues.
Old Jun 28, 2010 | 11:23 AM
JoeyBalls's Avatar
ok thanks, this wont jeopardize the integrity of the runner ( I sound like a nerd, lol) on the manifold right?
There are a lot of tight bends on my manifold and if its safer to just put it in the DP and add 200F I don't mind that either..........
Just trying to prevent a glowing manifold again, I figure the DP was glowing as well, so I know for sure the EGT probe in the DP would have been hot enough to let me know something is wrong.
Old Jun 28, 2010 | 10:36 PM
EngineerX's Avatar
That should work well, it'll be better than having no EGT sensor at all and It will still give you a good idea of how your engine is doing.
Just make sure you start your tap small so that the 1/8"npt sensor thread goes in tight, sometimes the thin wall pipes dont offer enough thickness for the sensor threads to grab onto.
Old Jun 29, 2010 | 05:14 AM
If you are putting it in your downpipe, I would recommend welding the bung and not tapping the pipe.
Old Jun 29, 2010 | 05:19 AM
JoeyBalls's Avatar
Yea we are going to weld in a bung.........
Old Jun 29, 2010 | 09:15 AM
dsddcd's Avatar
Old Nov 26, 2012 | 02:25 PM
Kyushin's Avatar
Banned
Are these numbers for a turbo application?
liquidgsr
Mar 16, 2012 08:29 PM
hondaguys2k
Aug 18, 2011 09:26 AM
dc2-2-ap1
Sep 1, 2010 06:28 AM
xasrielx
Feb 6, 2010 12:18 PM
KeithM
Apr 23, 2008 09:53 AM
