EGT prob on Full Race mani
EGT's are worthless unless you have 1 on each cylinder to compare temps. But if you were to put at least one EGT, it would be best on cylinder #3. The firing order is 1-3-4-2. If you look into that order, cyl. #3 is getting heat soaked by the cylinders firing next to it. Therefore you would want to put your EGT on the hottest cylinder only a couple inches away from the flange.
But like i said on each runner would be best
Originally Posted by roi,Oct 2 2007, 05:45 AM
number 3 it is, thanks
Are you using an AEM EMS ? If so, I would highly recommend using an egt on each runner because there is a parameter that lets you hook up 4 EGT sensors directly to the EMS. You can log the data or set up a fuel trim based on your exhaust temperature.
Originally Posted by SLW S2k,Oct 3 2007, 12:08 AM
okay, HERE is the picture of the FULL RACE CAR with the EGT welded in... for all thsoe non believers out there.. it's there.. on teh full race webpage..
ino20
Forced Induction For Sale
Sep 17, 2016 11:49 PM
