Electric Boost gauge Sending Unit
Old Sep 21, 2006 | 04:42 PM
pushin9's Avatar
Default Electric Boost gauge Sending Unit
I have the Nordskog digital boost gauge and the sending unit is supposed to thread into the intake manifold. Not sure I want to mount this thing in my intake manifold or where I would even do that.
For those of you with the electric boost sending units where and how did you mount your sending unit. And suggestions, pictures, or personal ideas would be much help!
Thanks
Old Sep 21, 2006 | 04:53 PM
Dsgs2k3's Avatar
buy a tee fitting and branch it off the fuel pressure regulator hose.
Old Sep 21, 2006 | 07:38 PM
Slows2k's Avatar
You need to find out what kind of threads are on the sender, them look for a fitting that has a female threaded end and a hose barb on the other. Most likely it's 1/8 NPT. Run a hose to any intake manifold vacuum source to the sendor. You'll have to T into an existing vacuum line, the FPR line works. You can also splice the vacuum line to the air pump control solenoid.
It's either that or drill a hole in the intake manifold and tap it for the needed threads.
Old Sep 22, 2006 | 05:31 AM
pushin9's Avatar
thanks (again) slow that is what I will do
RZA
Mar 29, 2016 06:41 PM
SilverstonedAP2
Mar 27, 2012 06:31 PM
Phillie
Dec 27, 2006 09:51 AM
folex187
Aug 16, 2005 01:22 AM
Patrick Jamex
Feb 1, 2005 11:16 PM
