wastegate PROBLEMSS
Old Mar 27, 2012 | 03:38 PM
SilverstonedAP2's Avatar
Default wastegate PROBLEMSS
so im about 90 percent done my turbo build, just not sure where i should connect the two nipples on my wastegate, theres one thats off the top and one on the bottom, thanks for the help guys!
Old Mar 27, 2012 | 03:43 PM
riceball777's Avatar
the top port is only used if you are running an electronic boost contoller.
Old Mar 27, 2012 | 03:59 PM
so block off the top and run the lower one to my intake mani? thanks alot man! also where should i run vaccum lines from my boost gauge?
Old Mar 27, 2012 | 04:20 PM
Sarek's Avatar
Also from the intake manifold. If you're not using an electric boost solenoid to control boost I think the top one is vented, not blocked.
Someone please correct me if I'm wrong.
Why don't you want to use a boost solenoid?
Old Mar 27, 2012 | 04:37 PM
redboost10's Avatar
Yeah just leave the top open if not using a bc.
Boost gauge from intake and wastegate bottom port from either the intake or comp housing
Old Mar 27, 2012 | 06:31 PM
spectacle's Avatar
Connect the bottom port to your compressor housing and leave the top port open if you're not using an electronic boost controller. If you're using a manual boost controller, route it inline with the bottom port.
RZA
Mar 29, 2016 06:41 PM
Deception
Aug 13, 2009 09:12 PM
jwa4378
Nov 19, 2008 05:50 PM
Patrick Jamex
Feb 1, 2005 11:16 PM
Yellow Streak
Oct 23, 2002 01:30 PM
