The eManage Magic Setting for Timing Control...
Old Jul 18, 2003 | 06:15 PM
Wesmaster's Avatar
Jason, aka St00pid, couldn't find his timing light when we did our test. At idle we altered the timing and you could feel/hear the motor change, somewhat like when you first turn on the AC...but it keeps running like that. Change the timing back and it runs like normal.
Old Jul 18, 2003 | 07:14 PM
mbitton's Avatar
I would like to say that i love you.
Question, if one would like to use the Emanage on a F/I car what would they need in regards to harnesses?
- E-manange
- Ignition harness
- Injector Harness
And when changing the timing, im guessing there is like a 16x16 map like how the fuel is set up?
Thanks once again.
Mike Bitton
Old Jul 18, 2003 | 07:23 PM
Wesmaster's Avatar
- E-manange
- Ignition harness
- Injector Harness
Also the eManage support tool, which is the laptop cable and the software. I would also recommend the Greddy pressure sensor so that you can tune on true PSI not just the MAP reading, which is probably being clamped by something like a Missing Link.
The timing map is 16x16 and works on 1 degree increments.
Old Jul 18, 2003 | 07:24 PM
Reignman's Avatar
- E-manange
- Ignition harness
- Injector Harness
Thanks once again.
Mike Bitton
You would use the ignition harness and there is a 16x16 ignition map
Old Jul 18, 2003 | 07:44 PM
mbitton's Avatar
Thanks so much. You've just saved me like a thousands bux...i was gonna go AEM but since im only running low boost i think im gonna stick with emanage until i go to like 28 PSI
thanks soooooooo much again
Old Jul 18, 2003 | 08:31 PM
beroznikmal's Avatar
you can use a knock sensor for tuning timing also..... set the timing as advance as possible without it knocking.... then if it knocks back it off some.....
Old Jul 18, 2003 | 10:18 PM
slick rick's Avatar
How does the e-manage compare with VAFC or AEM EMS?
What kind of price range is it?
Old Jul 18, 2003 | 11:39 PM
evo s2000's Avatar
[QUOTE]Originally posted by Wesmaster
[B]The magic dial settings to control timing with the eManage is 4-8-C.
Old Jul 19, 2003 | 03:29 AM
cjb80's Avatar
VAFC is good for car shows, e-manage is good for tuning, and a little for car shows.
Chris
Old Jul 19, 2003 | 04:39 AM
For bang for the buck the emanage is like super sizing your meal at McDonald............................
