The eManage Magic Setting for Timing Control...
Old Jul 23, 2003 | 12:54 PM
  #111
beroznikmal's Avatar
Wes,
How will you be hooking up your wide band O2 sensor. Those the Emanage have the capability to read a supplemental O2 reading besides the stock O2 reading.
Or are you going to hook it up to a O2 meter gauge and tune road tune the car via reading off from the WB O2 sensor??????
If this is the case, where will you be installing the WBO2, will you be drilling a new hole or will you be placing it at the exhaust tip.....
I ask this because I'm pretty sure the stock ECU will go LOCO if you replace the stock O2 with a WBO2.
Thanks
Beroz
Old Jul 23, 2003 | 01:30 PM
  #112
Wesmaster's Avatar
I've already gotten used to my CEL being on all the time (no cat). Although I did hook up an O2 simulator we think that the secondary O2 is actually bad (it looks like it's broken off). I'm probably not going to spend the money to replace it just to make the CEL go off, so I will probably just end up using that hole for the wideband. I don't know, funds for a wideband won't be around for a few months.
Old Jul 24, 2003 | 07:16 AM
  #113
SC-SUZUKA's Avatar
Wes, seeing now that the E-manage can add/remove fuel, and also retard and advance timing in our cars, this will be the ideal set-up for Nitrous S2000's. Am I wrong? Also, it should also help out a lot for the N/A S2000's also.
Chris C.
Old Jul 24, 2003 | 08:14 AM
  #114
Wes,
Let me get this right.....you replaced the stock O2 sensor that in connected to the header with a WBO2 and then puged it in to a WBO2 controller and then wired to the stock ECU? and the ECU work fine with that setup?
Beroz
Old Jul 24, 2003 | 08:37 AM
  #115
Wesmaster's Avatar
...and then puged it in to a WBO2 controller and then wired to the stock ECU?
No, it's a portable wideband. We just hooked it up and put the display on the dashboard so that we can see what is going on.
Old Jul 24, 2003 | 09:03 AM
  #116
yes.....can you tell me where you got this ...please......
Old Jul 24, 2003 | 09:11 AM
  #117
Wesmaster's Avatar
The one we were using is made by FJO ( http://www.fjoracing.com ). The web site is kinda funky. Look for the wideband link, then go to Packages, that will get you a look at the parts list and the product. To see prices you have to open the prices PDF and look for that part #. You will also have to buy the sensor seperately. It looks like it costs just under $700.
Old Jul 24, 2003 | 02:46 PM
  #118
cjb80's Avatar
www.wbo2.com
Old Jul 24, 2003 | 03:03 PM
  #119
TurboVtk's Avatar
Originally posted by 03spa
Yes, but you have to fill it up ever few days
water is free! lol at least when you rent!
Old Jul 24, 2003 | 06:25 PM
  #120
RT's Avatar
RT
[QUOTE]Originally posted by Wesmaster
[B]
