Emanage problem. Engine stalls
Old Mar 10, 2010 | 04:49 PM
myflys2k's Avatar
Default Emanage problem. Engine stalls
Today I started the car for the first time after installing a emanage ultimate with 550cc injectors. My car already had the comptech supercharger with 7 psi pulley. I removed the RRFPR that came with the kit so I could run some normal fuel pressures. My car is an ap1.
So today when I started the car forthe first time it started great. Idle was ok. Once I gave the car some gas it reved up then when it went to idle it stalled. So I started the car again and it did the same. If I slowly release the throttle i mean real slowly it idles fine. So I then decided to take the car for a drive. It drives fine with afr in the 14.4 to 15.6 range. When I pulled up to a stop sign. It stalled again. Started fine. The car doesn't seem to stall every time but I'd say 40% of the time.
Once thing I noticed in the emanage was at idle my throttle position is at 0.9%. I am not using any anti engine stall and all the maps related to fuel and timing are at 0s (except in boost which I haven't even gotten close to trying)
my injector compensation is 360cc lag 0.1 / 550cc lag 0.34
any ideas would be more than helpful.
Old Mar 11, 2010 | 09:41 AM
K-Lo's Avatar
your engine gets more fuel now from the 550cc's so you probably need to work on your I/J maps from idle to 3K at 0% ~ 10% throttle. Your engine is getting flooded with fuel. You would need to put negative values in your 0% throttle row to trim your fuel flow down.
Also it's a good idea to check and calibrate your throttle position as how the emanage sees it.
Old Mar 12, 2010 | 05:45 AM
myflys2k's Avatar
Looks like the problem may have been fixed. Recalibrated the throttle and all seems well. I'll have to take it for a drive to make sure. Thanks for the help
vader1
Aug 4, 2010 07:27 AM
SoCalIsMyLife
Apr 27, 2008 07:13 PM
Venomous S
Dec 5, 2005 04:50 PM
folex187
Oct 4, 2005 10:15 PM
folex187
Aug 21, 2005 04:16 PM
