Empty fuel from tank...
AP2
Returnless fuel system
Im looking for the fastest and best way to empty ALL the fuel out of the tank. Im moving over to E85 and I need to get my piss gas out of the tank. Some people are stating (pull the fuel line and run the tank dry.) But I pulled the fuel that runs from the fuel rail to right below the block and nothing would come out. I would need to put the key into the acc spot to get the fuel pump to prime and then I got a lil gas but them it stops. How should I go about getting the fuel out????
if all else fails pull the fuel filter and pump out (move to the side) and use a hose with a hand pump to syphon the fuel out that way. you can get a little pump and hose for 5-10 dollars at an auto part store.
AP2
Then, it's just a matter of jumping a wire from that relay to your battery, jumper cable, or whatever to pump it out once you disconnect your fuel feed line on the rail.
joefish1298
Jul 21, 2010 06:15 AM
