Engine problem
Old Jul 6, 2006 | 05:54 PM
Panda's Avatar
Default Engine problem
CAN ANYONE HELP ME OUT?
I have run into a situation with my engine. I bought a used comptech blower with aftercooler aslo with a AEM EMS and little upgrades. I also bought an ALaniz head. Since i got it back i have not run over 7 rpm because i was breaking in my new clutch. Well, i tried to dyno it and but there was something rattling or some kind of sparking NOISE happening after 6 rpm and so some were thinking it was maybe a valve. They knew it was not detonation so that was good. After running a few hundred miles later my engine shut down on me while i was on the freeway. I talked to greg from spugen and he said it sounds like the valve. But my engine still tries to turn over while trying to start... One funny thing that happened when my engine shut down, is that i couldnt put up my softtop right after! But after waiting awhile it went up.
Can you guys help me out of what i should check for?
*********Check my latest post*******
***** Car starts, than dies*****
Old Jul 6, 2006 | 07:15 PM
JDM S2000's Avatar
Banned
stupid answer, bad ground?
Old Jul 6, 2006 | 07:34 PM
icemans2k02's Avatar
did you throw a CEL at all?
Old Jul 6, 2006 | 07:52 PM
Slows2k's Avatar
I highly doubt a CEL was on if he's using an EMS.
A quick and dirty comptession check will tell you if you've got a serious compression loss, either in the valvetrain or rings.
A leakdown test will tell you where the leak is.
Old Jul 6, 2006 | 09:43 PM
duff0000's Avatar
^ dumb question but having an ems installed cuts out the CEL coming on if theres a prob?
Old Jul 6, 2006 | 10:53 PM
Chitah831's Avatar
The EMS replaces the stock ECU... so therefore no more stock ecu to give CELs
Old Jul 7, 2006 | 05:23 AM
jbotstein1's Avatar
I didn't know you needed to break in a clutch.
Old Jul 7, 2006 | 06:21 AM
didnt see he had ems thought he was still using the "black box".. i have heard rod knock on many a cars and valves flutter.. i am unsure of the spark noise though... hope you find out what is going on
Old Jul 7, 2006 | 06:22 AM
Panda's Avatar
I have a brand new clutch put in so it needed some breaking in. Yeah a compression test was recommended. My car is at my place so i trying to figure out which mechanic i can bring it to, since i cant drive it there, its kinda frustrating.
Old Jul 7, 2006 | 06:32 AM
Asura's Avatar
Regarding softtop:
Since they just replaced the clutch, there is a connector under the center console that may have been left disconnected. It's a signal from the handbrake and the connector is a simple spade. When it is not connected, you can't operate the softtop motors.
