Engine problem
Old Jul 7, 2006 | 03:23 PM
Panda's Avatar
I can put my softtop on now, it was just that i couldnt right after my engine shut off. I had to wait a couple minutes before it would let me put it up.
Old Jul 11, 2006 | 10:52 PM
Panda's Avatar
found the problem. It was the fuel pump or the fact that there was no fuel going to the engine. We replaced the fuel pump with the comtech aftermarket one, but still no fuel going to the engine, also that we still cant hear the fuel pump. The fuse is still good. We dont know whats wrong with it, or maybe you guys maybe know what to check? Need your help!
Old Jul 12, 2006 | 05:09 AM
fperra's Avatar
Sounds like it could be a grounding problem. There is a ground connector on the back of the head that is difficult to attach. Check it and see that it is bolted tight. Also, check the EMS programming and wiring, as your problem could be there. Swap in the stock ECU and see if the car starts.
Old Jul 12, 2006 | 12:54 PM
Panda's Avatar
thanks for the info. Please, anyone else got any ideas????
Old Jul 12, 2006 | 01:43 PM
kane.s2k's Avatar
If your fuel pump JUST turned off and all the wiring is ok, maybe someone turned the fuel pump off in the AEM EMS.
Old Jul 12, 2006 | 01:59 PM
Panda's Avatar
would the fuel pump in the AEM ems just turn off while driving? Has that happened before?
Old Jul 12, 2006 | 03:21 PM
kane.s2k's Avatar
no, I was asking if anyone played around with the EMS. I guess the answer is no. The most likely problem would be fuses/wiring.
Old Jul 13, 2006 | 03:10 PM
Panda's Avatar
thanks for the info kane.
Old Jul 20, 2006 | 03:46 PM
Panda's Avatar
OK after fixing some wires and fuel pump, my car starts now for like 2 seconds, than dies. I dont know what to check.... Im clueless so if you guys can help me out, with any advice on what to check, that would be awesome!
Old Jul 20, 2006 | 04:18 PM
fperra's Avatar
If your fuel pump is not bad, I'm going to guess something in the EMS MAP is messed up. Also, this is a long shot, check your battery - the EMS doesn't like low voltage. The fact that you heard some sparking noise when you dyno'd still makes me think it's an electrical issue.
