Engine problem
Old Jul 20, 2006 | 04:52 PM
  #21
R.P.M's Avatar
Originally Posted by fperra,Jul 20 2006, 04:18 PM
If your fuel pump is not bad, I'm going to guess something in the EMS MAP is messed up. Also, this is a long shot, check your battery - the EMS doesn't like low voltage. The fact that you heard some sparking noise when you dyno'd still makes me think it's an electrical issue.
I was helping Panda out with his problem and here is what we found:
-Broken wire on the connector on the Top Dead Center Sensor #2
-60amp air pump fuse was blown
-The EMS wont turn on the fuel pump, nor do I hear the relay click
The wire was fixed and the fuse was replaced.
We installed the stock ECU back in and the fuel pump works and I can hear the PGM FI relay click. That is how we can get it to start for a few seconds.
We also replaced his battery with a brand new one, which I checked with a volt meter and it is good.
Old Jul 20, 2006 | 04:57 PM
  #22
blues2k3's Avatar
btw..does the top still go up and down now? if you heard a spark if could have been a grounding issue..
Old Jul 20, 2006 | 05:21 PM
  #23
R.P.M's Avatar
The top works fine, and there is no sparking noise when it does run for a few seconds.
Old Jul 20, 2006 | 05:49 PM
  #24
blues2k3's Avatar
can you hook up a fuel pressure guage to check pressure?
Old Jul 20, 2006 | 09:10 PM
  #25
Panda's Avatar
i would need to take it to a shop for them to install a guage on my fuel rail. So im guessing we cant tell the fuel pressure, unless otherwise...
Jmpu671
Oct 11, 2016 10:54 AM
schwissig
Aug 14, 2013 09:07 PM
Jamie_Murray
Mar 8, 2010 04:39 PM
tokyo_james
Apr 11, 2004 08:20 PM
F1 Trainer
Dec 7, 2000 11:37 AM
