EVAP Cannister delete or manual purge...
I think it's possible that you do but aren't noticing it. I've had the problem as well but only noticed it recently and under certain conditions. When you have a straight exhaust with no cat the smell that it produces can almost mask the smell of the gas.
I just finished looking though the shop manual. It looks like there are two solenoids and a tank pressure sensor. The way it looks like it works is that the TPS (tank sensor) sends a 0-5v signal to the ecu. Once a certain voltage is met (not real clear in the manual) the evap solenoid opens and allows the vapor to go into the intake track to be burned. My guess is that since the EMS doesn't respond to the voltages and that solenoid stays open 100% of the time. Which means that while the car is sitting fuel vapor is allowed to flow into the manifold while the motor is not running.
Bay Area For Sale
Oct 17, 2016 09:53 PM
