Ever seen a Ford 8.8 diff break like this?
Old Nov 8, 2014 | 06:38 AM
wadzii's Avatar
Banned
the iron housing will bend or the bolt that holds the mount to the housing will bend/break.
Old Nov 9, 2014 | 01:24 PM
FullBlown's Avatar
Former Sponsor
We have never had any problems with a steel housing or bolts bending/breaking. We try to steer all of our customers away from the aluminum housing. Weight wise, it is not even worth it to consider the use of an aluminum housing.
Some of the fastest S2K's are running with a steel housing without any issues.
Old Nov 9, 2014 | 01:57 PM
ebdavis's Avatar
I believe they are iron housings.
Old Nov 10, 2014 | 03:43 AM
spectacle's Avatar
Originally Posted by 1SlowSi
Originally Posted by JayRSXS' timestamp='1415243291' post='23395330
Don't they call to use only the steel housing?
They recommend it because it's stronger but the aluminum ones will work as well.
Apparently not!
Old Nov 10, 2014 | 07:04 AM
1SlowSi's Avatar
Originally Posted by spectacle
Originally Posted by 1SlowSi' timestamp='1415274317' post='23395532
[quote name='JayRSXS' timestamp='1415243291' post='23395330']
Apparently not!
[/quote]
Always a dick man. I said the aluminum diff will work just fine because there are several people that have had ZERO issues with them. If they cranked up the power then maybe they will but for the average person not beating the hell out of it on the track, the lincoln mark Viii, and cobra diff will work.
As far as the steel housings go, you can run any thunderbird super coupe / IRS diff from 89-95. Just make sure it says 8.8 on the housing because they do make an 8" believe it or not.
Old Nov 11, 2014 | 01:35 PM
looksexyS2000's Avatar
over 1100whp here and 8sec car numerous passes on it and never broke a steel housing or bolts... the only thing i broke was the ring and pinion on a really sticky track
veehexx
Apr 26, 2009 10:36 PM
jfw432
Jun 16, 2007 09:24 PM
