excessive heat under hood
Old May 21, 2018 | 11:14 PM
RolanTHUNDER's Avatar
Originally Posted by DemiSlayer
Currently the headers have been coated internal and ceramic coating on exterior along with heat wrapping. i am using a heat spacer to the intake manifold. Radiator is a mishimoto with dual fans. There is also a carbon fiber front shroud cover of which i have been considering removing.
i have verified that coolant is flowing properly through the engine.
What i mean by excessive heat is its dramatically hotter then most turbo vehicles i have worked on. its hotter then some cars i have ran on my dyno for a number of hours vs driving this thing for 15-20min around the block with no boost.
I am also considering an oil cooler.
Seems like heat isn't escaping. Oil cooler plus venting the hood may be the only things you can do now and should alleviate the excessive heat issue. As long as the engine itself isn't overheating then this is all just out of caution's sake but you can never be too cautious especially in a boosted scenario.
ITR
Dec 31, 2019 05:54 AM
macr88
Body
Jan 14, 2010 06:01 PM
KeithD
Aug 30, 2001 09:14 PM
