Exhaust leak
Old 05-20-2014, 11:04 AM
mirabileboy's Avatar
Default Exhaust leak
Fixed
Old 05-20-2014, 01:02 PM
joes sled 2000's Avatar
First verify that you wide band reading is accurate . Then if it is a retune will be needed . If it isn't accurate then fix it first and go to the 2nd step .
Old 05-20-2014, 07:08 PM
baZurk's Avatar
What ems are you using?
Old 05-20-2014, 10:55 PM
MBHs2k's Avatar
Even before the leak your car was running too rich.
Old 05-21-2014, 04:39 AM
baZurk's Avatar
Is o2 feedback on? If so the ems should be pulling fuel to match the target afr. Even removing your exhaust, the ems will do SOMETHING to bring your AFR closer to the target number.
My AFR's at idle tend to swing around a lot especially after starting the car or coming to a stop at a light or something.
Old 05-21-2014, 05:20 AM
baZurk's Avatar
If you haven't already, I suggest you download AEMtuner on to a laptop just so you can connect to your ems and check things out.
Old 05-21-2014, 07:46 AM
That Guy 1987's Avatar
What is your AFR at idle. Mine is the same as his but tuner says it's necessary for a decent idle. In for some input.
Old 05-21-2014, 08:22 AM
MBHs2k's Avatar
I'm SC if that matters, running ID1000s. My idle is always around 14.2-14.7
Old 05-21-2014, 08:26 AM
baZurk's Avatar
Originally Posted by mirabileboy
What laptop supports the VGA connection?
You should have a USB cord. That is what I used.
Old 05-21-2014, 09:32 AM
APoner's Avatar
ID 1000
AEM 320lph
stock fpr
stock fuel pressure 43psi
Idle afr 14.7-14.9 ALWAYS
cruise/ part throttle afr is also 14.7 - 14.9
Quick Reply: Exhaust leak
