A/F bouncing around at idle help!
Old Sep 21, 2015 | 02:19 AM
lude92_si's Avatar
Default A/F bouncing around at idle help!
hey guys my a/f has been bouncing around at idle when car is warm. From 13-16.9 back n fourth. sometimes it will want to stall. runs normal when driving just having issues at idle. did some logs for my tuner he said the tune looks fine it's not the tune...what should I look for? I cleaned the IAC still nothing. ..
I'm running id2000 with aem v2 ems on e85
any ideas?
Old Sep 21, 2015 | 03:14 AM
Erajk's Avatar
My did the exact same thing when my fuel pump failed. Can you try borrowing a friends?
Old Sep 21, 2015 | 03:17 AM
lude92_si's Avatar
my fuel pump is new. and car runs fine when driving just idle...
Old Sep 21, 2015 | 05:31 AM
Habitforming's Avatar
What aem firmware, 1v24 or 2v02? I had strange afr issues when I tried 2v02, both at idle and light cruise, and had to revert to 1v24. Solved the problem instantly, but I lost some functionality.
Old Sep 21, 2015 | 07:41 AM
lude92_si's Avatar
I'm not to sure...I bout the ems brand new and had it tuned in October last year..it's never been 100% where I would like it. it was idling decent for a while then now this...bad wideband? bad map sensor? guess I will look into those first.
Old Sep 21, 2015 | 01:30 PM
cheddaboy's Avatar
Mine used to die too but ran some injector cleaner in the tank and so far it's working. It's stil idles pretty lean u less I tap the gas pedal
Old Sep 21, 2015 | 03:06 PM
lude92_si's Avatar
brand new id2000s as well. normal driving and under boost everything is fine
Old Sep 25, 2015 | 01:33 PM
siadam's Avatar
Mine hasn't been much better with the ID2000's. Seems some guys get them to idle clean, others are exactly like you are describing.
DiegoB16
Mar 31, 2017 10:29 AM
gacklez
Aug 11, 2014 01:34 PM
spapdx
Jun 1, 2014 02:44 PM
s2kseven
Sep 20, 2012 01:56 PM
EK9MAX
Jun 29, 2010 11:28 PM
