F22 long block questions
Old Oct 16, 2014 | 08:44 AM
liquidgsr's Avatar
Default F22 long block questions
Does anyone know if I buy a AP2 F22 V1 long block, if I can swap my sensors over and my intake manifold to put in my MY07. I know the manifold is different and I run a DBW while the AP2V1 runs a wire rather than the sensor. I am wondering what else is different.
Old Oct 16, 2014 | 09:34 AM
S.2.K's Avatar
have to use your 06+ valve cover, change the trigger wheel on the crank, and change the trigger wheel on the exhaust cam.
Old Oct 16, 2014 | 11:32 AM
liquidgsr's Avatar
Ok I have those. Im planning to use my own valve cover. Do you know if the intake manifold will bolt up. What is the trigger wheel?
Old Oct 20, 2014 | 06:28 AM
RDS2K's Avatar
Intake manifold will bolt right up. Trigger wheel is another name for the sensor I assume.
Old Oct 20, 2014 | 07:44 AM
liquidgsr's Avatar
Ah thanks.
Old Oct 21, 2014 | 04:00 AM
donaldmejr's Avatar
The trigger wheel is on the crank it's a little disk with indicator "flags" on it that the sensor picks up. The sensor is right next to the crank pulley and it held in place with one m6 bolt
Sent from my iPhone using Tapatalk
drifts2
May 18, 2017 07:41 AM
THE BOM3
Mar 6, 2013 02:27 AM
ChefJ
Jan 23, 2009 07:28 PM
S2Gizzle
Dec 23, 2005 02:33 PM
