gaugeART on S2000 in Venezuela
Old Oct 2, 2014 | 08:16 AM
ScienceofSpeed's Avatar
Former Sponsor
Default gaugeART on S2000 in Venezuela
Check out this gaugeART working with AEM Series 2 in Venezuela. Great job Kartec Tuning!
http://instagram.com/p/toZEJUw5az/?modal=true
more info:
http://scienceofspeed.com/products/e...gauge_adapter/
Old Oct 3, 2014 | 07:47 PM
Spoolin's Avatar
That is sweet! It's just too bad you need to cut your dash and make some pretty significant modifications.
Old Oct 5, 2014 | 11:11 AM
kartectuning's Avatar
thank you guys!!
With the help of our good upholster guy we flocked the dash with alcantara and with some automotive bondo with the dash lines an oem look for the honda oem bezel to fit the 7.5 inch screen, the s2000 is so tiny that if you put a set of gauges it will look really flooded, the gauge art setup really helps and improve the data viewing, engine safety and tuning process.
We have set 12 channels on our gad, file working with the online gauge designer software, after a few tricks it worked perfect, the data stream is pretty accurate with fast response and no delays at all!!!
We really recommend this product!!! thanks to the people of science of speed for setting all the pieces needed for our s2000
DJ @kartectuning
Old Oct 5, 2014 | 11:19 AM
we added fuel temp fuel press oil ten and oil press sensors and made the pull high circuits for the temp sensors on the 0 to 5 volts channels on the aem
4 adcrs are fitted to the aem series 2 for the s2000, 3 of them straight forward, 1 is tricky as is set for mac volts so you need to set the sensor cal analogue in to that parameter and then set the sensor cal table
Old Oct 6, 2014 | 11:41 AM
Krisbuc's Avatar
Does the screen fit where old navigation screen sat or is it bigger ?
Old Oct 19, 2014 | 02:48 PM
https://www.facebook.com/video.php?v...type=2&theater
Old Oct 20, 2014 | 01:22 AM
Krisbuc's Avatar
^^ link not working
Old Oct 21, 2014 | 09:43 AM
Former Sponsor
Thanks for the feedback Kartec!
In the meantime, here are some photos of an install we did using the factory display pod (which we have in stock, if you need one). Kartec went a step further and had the dash molded.
We're working on a non-permanent solution as well, to be released in several months.
RedCelica
Dec 6, 2016 04:33 AM
Tegiwa Imports
UK & Ireland Traders Forum
22
Oct 9, 2016 01:19 AM
JSanford2032
Nov 8, 2014 02:36 AM
nomadicS2k
Jun 6, 2009 12:37 AM
ladius
May 12, 2006 01:23 PM
