False Fuel Levels
Old Jul 15, 2007 | 08:19 AM
Reaper 6A's Avatar
Default False Fuel Levels
I had just gotten my Vortech Supercharger installed when i was driving to work 2 days later it started acting crazy. Fuel pressure dropped to 30psi and car started stuttering. I checked the fuel level and it was reading 1/3 tank. I started driving and it was stuttering like it was starving for fuel. Then it the car just quit running. I checked for pinched fuel lines and listened for the fuel pump to come on and everything was fine. The shop that installed my blower took it to the shop and started trouble shooting it. Come to find out, the gas tank was bone dry. Absolutely no fuel in the tank. Filled it up and everything is running great now. Has anyone ever had their S2K give you a false fuel reading and then run out of gas??
Old Jul 15, 2007 | 08:35 AM
vtec-man's Avatar
hmmm, probably a problem with the fuel pump assy and the floater for the gas level indicator...
Old Jul 15, 2007 | 08:43 AM
Slows2k's Avatar
Don't use the fuel pump sock that comes with the Vortech kit. It's angled and blocks the senders float arm. The sock is meant for an Integra, not a S2000.
Reuse the S2000 sock or get a new one.
Otherwise you have to bend the float arm around to clear the angled sock.With the angled sock the fuel pickup is not flat on the tank, and can lead to fuel starvation under cornering.
Old Jul 15, 2007 | 12:59 PM
vtec-man's Avatar
what is the fuel pump sock ????
Any pic ?
Old Jul 15, 2007 | 01:33 PM
5thelement's Avatar
its the filter that goes on the end of the fuel pump i had this same problem but i knew imediately wat it was or you can just angled it a little bit like i did
Slows2k's Avatar
It's the part that is attached to the fuel pump inlet. I don't have any pics of one.
Old Jul 15, 2007 | 07:04 PM
NFRTurboTerror's Avatar
Here is a pic of my walbro.
RAIN H8R
Feb 22, 2024 07:42 AM
joefish1298
Jul 21, 2010 06:15 AM
siadam
Apr 25, 2009 06:53 PM
S2KPiGGy
Jan 11, 2004 08:26 PM
