FB Dual Pump Hanger
Old Sep 8, 2011 | 08:42 PM
  #31
siadam's Avatar
Originally Posted by Spoolin
I guess it's just me then. LOL When I see 4 12ga wires (2 one color and 2 another color) I immediately know what those wires are for because of their size, amount of wires only in that size and the way the colors are split up. Then when I see the last wires that are smaller, I immediately know they are for the fuel level sensor. It doesnt matter where you use the colors of the wires (ie, black for power instead of the red and red for the ground, etc.) as long as you understand where the sizes of the wires belong and you hook up both ends in the same manner. Larger wires are always going to be for power runs and smaller wires are for signals, etc. It's just supper simple to me I guess.
Really? B/c I've hooked up quite a few things, and that isn't always the case. Why guess? B/c at best that is what you are doing.
Old Sep 8, 2011 | 08:44 PM
  #32
donaldmejr's Avatar
Originally Posted by manny-s2000
Yeah that's the other thing I was thinking does it use the stock float for the fuel?
just found them...check the last page of booztins build
Old Sep 8, 2011 | 08:49 PM
  #33
manny-s2000's Avatar
Hmm ok I will check it out.. The other thing I'm trying to work out, when you're wiring the pumps up, do u get power direct from the battery? I have basically used up all the sources in the fusebox area under dash(defi gauges, waterpump for ac, turbo timer) also what sort of fuses do you trigger the pumps with?
I wouldnt mind paying a shop to do all this but down here is aus, if u want to do a job properly u need to do it yourself.
Old Sep 9, 2011 | 04:20 PM
  #34
Spoolin's Avatar
Because you're not guessing when you're hooking both ends of the wire up. You know what's hooked up on the pump end in the tank and you also know what's hooked up on the battery end; this isn't something you're hooking up blind. LOL If you were only hooking up one end of the wire and the other end is already pre-hooked up to something else, then yes; you must know the correct way it needs to be wired.
Old Sep 9, 2011 | 04:31 PM
  #35
Spoolin's Avatar
The wire to trigger the pump on and off is already back there; it's the small 18ga stock yellow/green wire that used to power the stock pump. That's the one you use to turn the pumps on and off with the key when you hook it up to the 2 relays switch side. The other 2 main 12ga power wires (green and black) are the ones you hook from the relay power off the battery for the pumps (green for power off the relay and black for the ground off the relay to the pumps or vise versa; it doesn't matter as long as you hook both sides of the wire up the same).
Old Sep 9, 2011 | 04:34 PM
  #36
Spoolin's Avatar
Yes; it uses the stock float and sensor. They come off the stock hanger as one unit and there are tabs that slide into the new twin pump hanger to hold it on just like the stock hanger. There is also a small allen screw that gets put in to lock it in place.
I swear it's not rocket science. LOL
Old Sep 19, 2011 | 09:40 PM
  #37
Whats the easiest way to access the feed hardline guys?
Old Sep 20, 2011 | 01:55 AM
  #38
Also the supplied round fuel filter(cylinder with 2 hose connections) where is the best place to mount that?
I'm guessing it's for the feed line because the return remains the same.
And as for the return line (stock barb type) does that just fit on the supplied return fitting?
Sorry guys I have to do this myself because I don't think anyone here in aust will do it the right way without charging me a crapload.
Old Sep 20, 2011 | 03:41 PM
  #39
Spoolin's Avatar
I'm on my phone and can't post up my build thread, but if you search for my build thread about the FB dual pump setup, I have pics in there on the way I mounted the filter. Its basically on a piece of lexan where the spare tire was and the lexan is velcro'd to the car with industrial velcro. This way I can just pull the lexan plate off anytime I need to get to the filter. Everything is also covered with the factory panels and you would never even know its there.
Old Sep 20, 2011 | 03:54 PM
  #40
FullBlown's Avatar
Former Sponsor
Manny, we put the filter right next to the tank under the car. The return, you just use the stock barb fitting. The stock return is rubber, so you just use our supplied fitting.
