FB dual pump help
Old Jun 18, 2010 | 08:41 PM
D1sclaimer's Avatar
Originally Posted by Spoolin,Jun 18 2010, 09:19 PM
Also, the Full Blown etching on the top will read towards the drivers side of the car when the hanger is put in correctly if I remember right.
This is the best/easiest information that I have received. I must have been trying to put it in backwards because now the holes line up perfectly and I don't feel the level arm hitting anything. Now the trick is to take it out, put the fuel socks back on and put it back in. I think I will order a new gasket/big o-ring for under the hanger mount too to be safe.
Thanks for your help man. I should quit assuming the worst with everything.
PS because of the misinformation that I have posted, I will edit my above posts accordingly to prevent negative views upon the product.
Old Jun 18, 2010 | 09:30 PM
BlkMugen's Avatar
Glad you got it figured out now.
Regarding the bolt pattern being wrong on mine. I tried rotating the hanger and no orientation worked so i just drilled new holes. And i have a 07 DBW, not sure if the bolt pattern is different. After the few problems i had i figured i may have gotten the hanger for another car by accident.
Old Jun 18, 2010 | 10:53 PM
Spoolin's Avatar
Glad to help man and glad it fixed it.
With the sock filters on, its a little tricky to get into the tank but if you just finnagle it around a bit, it will go right in. I had to lean the hanger in a way that I could get the fuel level float in and then I ever so easily let the socks hit the edge of the hole and bend up a bit as I guided everything in and it dropped right in. i did mine from the trunk just so you know too.
Old Jun 20, 2010 | 09:32 AM
FullBlown's Avatar
Former Sponsor
We have sold and installed this kit in many cars. The bolt pattern should be right if you have it position correctly.
samsam
Apr 4, 2019 08:43 AM
ScienceofSpeed
Jul 14, 2014 01:06 PM
PatS4P
Jun 22, 2008 09:33 AM
