ferrea
Old Jan 6, 2006 | 05:49 PM
S2oooNvegas's Avatar
Default ferrea
just want to ask, has anyone here experienced interference with ferrea valvetrain? the retainers will contact the roller in the rocker.
the head in question was done recently by a well known cylinder head specialist. i assembled the head and went to adjust the valves. noticed when i looked close, no clearance between the roller and retainer. i checked, and with the rocker resting on the tip, no clearance. with the .009" feeler in there, i could just see some light, and measured .002" between roller and retainer.
well, i was alarmed and had the head builder come look. he said he hadnt seen this before. he spoke with ferrea over the last few days and they said, if you can see daylight, your OK. well, i dont like that, and neither does he. so hes been messing with it, and the manley retainers are shaped a tad different, and clear quite well. so at this point its a mystery. i wonder if most guys even check. i could have just adjusted the valves and let it roll. but i looked close, and noticed.
thats why im asking, has anyone else even looked? at this point, gonna be all ferrea with manley retainers. thanks ahead for any info. ill put this in tech section also, so it gets some coverage. late dave
Old Jan 6, 2006 | 07:36 PM
Slows2k's Avatar
I've got 1st hand experience with Ferrea valves and retainers using REV springs that bent valves from retainer to rocker contact.
All REV components solved the clearance issue. (springs, retainers, valves)
REV makes different retainers for the REV springs or stock springs. The retainers top contour and inside spring locater dimensions are different.
Old Jan 7, 2006 | 05:37 PM
thanks. ill ask about that. cause this setup is all ferrea. and looks like we would have had that problem. hmm. lates
Old Jan 8, 2006 | 05:29 AM
Sideways's Avatar
Alaniz has retainers that give clearances so as not to interfere. This is a long standing problem with Ti retainers.
Old Jan 8, 2006 | 02:27 PM
looks as though we will be running all ferrea, with manley ti retainers. different design. lots of clearance, better seat pressure etc.
Old Mar 14, 2007 | 07:39 AM
bigpurp's Avatar
I have a complete Ferrea valvetrain (valves, dual springs & retainers), so this is VERY concerning to me. My mech just took my head apart due to some noise (turned out to be the damned TCT), so I will ask him about this.
Where's the best place to get Manley retainers?
Old Mar 14, 2007 | 09:53 AM
GDM S2K's Avatar
I have ferrea as well and no problems when my head builder assembled it
CaymanS2k
May 20, 2007 04:47 PM
ERL_S2000
Mar 24, 2007 08:27 PM
SpiralF20
Mar 6, 2006 02:26 AM
