Ferrea beehive spring Ti retainer install
Old May 17, 2012 | 07:46 AM
indi00's Avatar
Default Ferrea beehive spring Ti retainer install
Plan was to finish by lunch time...
I guess not!
I really don't want to take off the head.
Old May 17, 2012 | 08:04 AM
EOE's Avatar
EOE
I am guessing the only way is to drill the inside out and reverse thread. RIght?
Old May 17, 2012 | 08:22 AM
indi00's Avatar
Tried tapping the side to loosen it up, but was a no go.
Ordered this at Sears, going to go pickup in a bit http://www.sears.com/craftsman-10-pc...p-00966196000P
The bolt flange 95701-08090-00 BOLT, FLANGE 8X90 is 0.89 at Majestic. $74 next day air. $8 ground. Called the dealership, $3 4-5 days wait..
Last resort is take the head off, and get it helicoil.
Old May 17, 2012 | 08:29 AM
05TurboS2k's Avatar
Quick option I use is to drill the middle of the bolt a couple mm, then use a QUALITY phillips head screwdriver and pound it with one decent size hit into the hole you drilled. press down very hard as you try to turn, if it doesn't come right out, move on to another plan like left handed drill bits etc.
Old May 17, 2012 | 11:58 AM
Kyushin's Avatar
Banned
Ya... that could end up being hell if it doesnt come out by time its really bored out ><. Thats why I use an impact drill to take shit out, I never trust screws cause they just LOVE to strip out
Old May 17, 2012 | 12:51 PM
indi00's Avatar
success! The bolt extractor broke at the tip, but the pounding loosen the bolt enough to be screwed out.
Old May 17, 2012 | 12:55 PM
s2knoob89's Avatar
Old May 17, 2012 | 03:01 PM
indi00's Avatar
Got the first one done... install wasn't too bad.
Sits a little lower?
Old May 17, 2012 | 03:31 PM
Importedpower's Avatar
did you put the base plate on? and retainer height doesnt matter, its the height of the valve stem piece, as that one looks to be the right height.
Old May 17, 2012 | 03:48 PM
indi00's Avatar
Made sure to installed the correct intake seat locater. Can easily get the exhaust and intake seat locater mixed up. The valve stem height is about the same.
