FI Noob what elese do I need?
Old Mar 10, 2009 | 04:59 PM
fridayfred3p's Avatar
Default FI Noob what elese do I need?
So, I trying to get together parts for a turbo build, shooting for hopefully 300-400 whp.
What else do you guys think i'll need?
Old Mar 10, 2009 | 05:32 PM
dsddcd's Avatar
Well you didn't give us much to work with but:
(1) Walbro 255LPH
(1) Map Sensor
(1) Wide Band, looks the the EMS is a 1052U
(1) Rear Exhaust
(1) Test Pipe or HF Cat
(1) Boost Controller
(1) Spark Plugs (8 Heat range)
(1) Couplings & Clamps for the IC piping
(1) Air Filter
(1) Oil Filter Relocation Kit
(1) ARP/Stage 8 exhaust studs
(1) 3 way 1/8" NTP Fittings and oil line adapter for the Turbo Feed
Possibly a FPR and Guage
Clutch
Oil Cooler
New Valves and Springs
I am sure there are a host of ther small parts you will need. If you want 350-400 you can get there on stock compression and a good tune but be carfull.
Old Mar 10, 2009 | 05:39 PM
s_d2k's Avatar
why he needs new ones??
Old Mar 10, 2009 | 05:57 PM
Spec_Ops2087's Avatar
I think he was listing that as a "possible" depending on the condition of the motor.
Old Mar 10, 2009 | 07:10 PM
sbrodacz's Avatar
Banned
I have a set if he's interested.
Old Mar 10, 2009 | 08:13 PM
dsddcd's Avatar
I needed them and after talking with lots of tuners the valves from the factory do not stand up the the increased cylinder temperatures.
Old Mar 10, 2009 | 09:00 PM
sbrodacz's Avatar
Banned
^ your looking for a set?
Old Mar 10, 2009 | 09:39 PM
nightcrawler7188's Avatar
you need $$ for just in case
Old Mar 10, 2009 | 09:45 PM
sbrodacz's Avatar
Banned
A good tuner.
Old Mar 11, 2009 | 07:23 PM
2big4aS2000's Avatar
factroy springs are good to 500hp, it is all in the tune!
