FI Noob what elese do I need?
Originally Posted by dsddcd,Mar 10 2009, 06:32 PM
Well you didn't give us much to work with but:
(1) Walbro 255LPH
(1) Map Sensor
(1) Wide Band, looks the the EMS is a 1052U
(1) Rear Exhaust
(1) Test Pipe or HF Cat
(1) Boost Controller
(1) Spark Plugs (8 Heat range)
(1) Couplings & Clamps for the IC piping
(1) Air Filter
(1) Oil Filter Relocation Kit
(1) ARP/Stage 8 exhaust studs
(1) 3 way 1/8" NTP Fittings and oil line adapter for the Turbo Feed
Possibly a FPR and Guage
Clutch
Oil Cooler
New Valves and Springs
I am sure there are a host of ther small parts you will need. If you want 350-400 you can get there on stock compression and a good tune but be carfull.
(1) Walbro 255LPH
(1) Map Sensor
(1) Rear Exhaust
(1) Air Filter
Clutch
Oil Cooler
This is what you do need:
-Walbro 255LPH
- Boost Controller
- Spark Plugs (8 Heat range)
- Air Filter
- Clutch
- 3 way 1/8" NTP Fittings and oil line adapter for the Turbo Feed
Possibly a:
-FPR and Guage
-Oil Cooler
-Rear Exhaust
-Test Pipe or HF Cat
-Oil Filter Relocation Kit
- ARP/Stage 8 exhaust studs
kevos2k
Nov 28, 2011 01:40 PM
