FI water/oil temp question
Old Aug 26, 2008 | 04:01 PM
E-autosports's Avatar
Default FI water/oil temp question
Hi Everyone,
I've recently installed the KW high boost kit on my car. But I'm having really bad over heating problem. Just wonderin what do you guys get for water & oil temp while NORMAL DRIVING and TRACKING. Any input is appreciates it.
Under 95 degree hot day, normal driving 65 mph on Freeway with A/C on. I got 245 water temp and 240 oil temp.
Engine and cooling mods.
KW high boost kit
Toda header heat wrapped
Stock cat
70mm ASM Ti catback
ARC radiator
Mugen low-temp thermostate
Gizzmo intake manifold gasket
It's 06 AP2
**Thermostate is new. Changed the radiator cap two times from 1.1bar to 1.5bar. Problem still haven't resolve.
Thank you.
William,
Old Aug 26, 2008 | 04:09 PM
corners2's Avatar
Bad thermostate maybe? If its the only other thing you changed besides the kit I would point the finger at the new parts???
Spec_Ops2087's Avatar
Water temp is way to high....
Oil temp is fine though.
Old Aug 26, 2008 | 04:52 PM
Slowmotion's Avatar
I know I am not FI, but I had a mugen thermostat and it was constantly sticking. it would overheat for a while and all of a sudden it would drop back to normal for a little while then go back up. I really don't like the mugen thermostat to much anymore. Try to put your stock thermo back in and see if that will help. Hope you get every thing back in order and I hope this post helps.
keep us updated!!! please.
-Greg
Old Aug 26, 2008 | 04:58 PM
jbotstein1's Avatar
Is your system properly bled? Make sure you have no air in it. Other than that I haven't heard of many sc guys having heat issues.
Old Aug 26, 2008 | 07:24 PM
PatS4P's Avatar
Banned
Coolant temp in your scenario 185-190. Oil temps 185-195.
Old Aug 26, 2008 | 08:35 PM
Hi guys,
Thanks for all your info.
[QUOTE]I know I am not FI, but I had a mugen thermostat and it was constantly sticking. it would overheat for a while and all of a sudden it would drop back to normal for a little while then go back up. I really don't like the mugen thermostat to much anymore. Try to put your stock thermo back in and see if that will help. Hope you get every thing back in order and I hope this post helps.
-Greg
Old Aug 28, 2008 | 06:19 PM
Slowmotion's Avatar
So is it running better?? Hope that helped you!!
Spec_Ops2087
21
Jul 19, 2011 03:27 PM
ktmpixie
Dec 23, 2010 12:52 AM
s_d2k
Aug 18, 2009 10:04 AM
pinoyk20
Jan 20, 2008 06:59 AM
Stratocaster
Sep 26, 2003 10:40 AM
