FIC woes
Old Sep 29, 2008 | 07:37 PM
TelosHedge's Avatar
Default FIC woes
anybody using an FIC and throwing this code?
its some TDC sensor for one of the cams i think - i forget.
seems to be a common problem on the aem forums - anybody find an answer?
Old Sep 30, 2008 | 06:05 AM
SgtB's Avatar
Does the fic tap that line? It's probably sinking too much of the signal.
Old Sep 30, 2008 | 07:26 AM
TelosHedge's Avatar
yes it does. i figure its eating up a bit too much voltage - i know the wiring is correct because i ran the harness last night with the AEM bypass plug and had no issues.
Old Sep 30, 2008 | 12:02 PM
SgtB's Avatar
Maybe try putting a resistor on the fic line.
Old Sep 30, 2008 | 01:14 PM
TelosHedge's Avatar
i have acquired another unit in the meantime. same model number, same revision. this one works just fine - no codes!
some of these units are bad.
however, now with the new one i have another issue. i can feel the car hesitate somewhere around the 3500rpm mark. i'm not overly concerned with this really, but i would definitely like to rule out any knock/detonation potential. would the car throw a code if it detects a knock big enough to cause hesitation?
Old Sep 30, 2008 | 01:18 PM
SgtB's Avatar
Not really. The F2x is too loud at WOT for the sensor to be usfull. The ecu stops listening at wot.
Old Sep 30, 2008 | 02:00 PM
TelosHedge's Avatar
this is at normal driving, sorry forgot to clarify
Old Sep 30, 2008 | 02:53 PM
SgtB's Avatar
You may get random misfire codes, but I strongly advise against using the cel as a tuning tool. Det cans are the best way to go. Are you running a wideband, and does the fic offer datalogging?
Old Sep 30, 2008 | 06:17 PM
2big4aS2000's Avatar
is this the standard fic or the one modified (now make different model# for my 2000-2005)?
if it is the standard fic you need to send in to have updated to your model year car.
Old Sep 30, 2008 | 07:33 PM
TelosHedge's Avatar
it is the correct unit.
i got a hold of ANOTHER 1912 and the CEL is gone. this old one is going back.
chtmatthew
Feb 13, 2019 05:58 AM
sloo2k
Nov 7, 2017 11:06 PM
Tampa s2000
Dec 19, 2015 02:54 PM
oxhouser
May 18, 2008 07:35 AM
spinmasterext
Jul 20, 2005 11:40 PM
