AFR
Old May 17, 2008 | 11:49 PM
oxhouser's Avatar
Default AFR
Just ordered an AFR meter from AEM, as i understand it I replace the lambda probe with the wideband sensor then connect one of the wires from the gauge to the loom that used to go to the lamda sensor (this is the signal the EMS requires)
does anybody have a wiring diagram or good suggestions as to do this without cutting the plug off the oem loom?
Old May 17, 2008 | 11:58 PM
MB's Avatar
MB
Member
Is it a complete new sensor with its own cable?
Are you using a standalone AEM EMS?
Old May 18, 2008 | 12:00 AM
Itchy Dick's Avatar
I think he'll be using the AEM FIC mark as that's in the TTS SC package.
Old May 18, 2008 | 02:08 AM
Bibbs's Avatar
i went with a diff company for my wideband.
It came with a whole loom. I had to unclip the stock sensor add in a resistor for the heating cel that appeared. Then clip a wire into the ecu for the primary o2, and set the controller to have its output as narrow for the stock ecu.
I did post about it. But search is broke.
Old May 18, 2008 | 03:35 AM
oxhouser's Avatar
Ok now i am confused
this is what I thought i was doing
I have the AEM UGO wideband AFR meter with sensor
remove oem sensor and fit new sensor
from the gauge there is an output wire that gives 0 or 5 v this is the signal the narow band sensor usualy sends to the ECU and the ecu needs it for closed loop control am I correct to this point ?
not sure on the heater bibbs so any info you have please send
Old May 18, 2008 | 05:13 AM
RedUn's Avatar
oxhouser that sounds correct to me.
Old May 18, 2008 | 06:51 AM
mikey k's Avatar
Leave it as a standalone gauge.
It has the ability to retransmit the wide band signal to an aftermarket ECU when you need it.
Weld an extra bung in for the sensor.
I put one in my cat
Old May 18, 2008 | 07:29 AM
RISLAR's Avatar
Old May 18, 2008 | 07:32 AM
Kiwi-S2000's Avatar
Looks like a little extra welding to do
Old May 18, 2008 | 07:35 AM
RISLAR's Avatar
Its alot easier to do it on a decat then replace the lot
Jaspah
Nov 5, 2015 01:13 PM
Hershey
Sep 23, 2014 06:32 AM
thanasis11
Nov 9, 2013 05:20 PM
3ngin33r1
Jan 15, 2009 09:01 PM
Diddy
Aug 14, 2002 10:07 AM
