Finally joined the 500 club :D
Originally Posted by passmans2kny,Jan 27 2008, 08:31 PM
thats sick man, post some pics of ur set up
However, I will post some pics when I get home later this week
Originally Posted by Spec_Ops2087,Jan 27 2008, 11:24 PM
stock
And yes its a GT35R, turbo is good for 650rwhp with a built motor
Good job proving otherwise.
congrats jonathan!
What are the specs of your GT35? What is your A/F?
Gotta love that flat torque curve! Looks exactly like your old one.. only with about 50 ft/lbs more
Congrats on the numbers and lets get another run with marcus
Originally Posted by Soul Coughing,Jan 28 2008, 01:54 PM
congrats jonathan!
I'll run him again once I get my little wastegate issue resolved
Originally Posted by Spec_Ops2087,Jan 28 2008, 01:59 PM
.62A/R ratio GT35R, A/F is mid 12's till vtec then it drops to low 12's
Be very careful running A/F's in the 12's. That's a very unsafe area and especially with pump gas. It would be a lot better and safer in the mid to upper 11's.BTW.......What's up with the low TQ numbers? I would think you would be closer to 340 as at 455 whp I was at 310 lb ft.
Good numbers none the less and welcome to the 500+ whp club.
Originally Posted by Spoolin,Jan 28 2008, 12:17 PM
WOW!
Before you respond to this comment just think, you don't know his AIT, his cooling mods, his timing curve, his altitude.
Also before you make a comment you and I both know the mathematical formula for peak torque combustion lands a A/F value in the low 12's.
So if the car had a proper cooling system, good timing curve, good fuel and fueling set-up, the 12 is ideal for power and safty as it would lead to ideal combustion and lower EGT's.
I would not jump on your comment if he had posted his entire set-up and he was running a small turbo out of its efficiency, or a small intercooler, or had a bad fueling set-up, or was high on the duty cycle of his injectors
THEN: like you I would chime in and say hey, maybe dump some extra fuel in there to make up for your _________ in your set-up.
To say running a 12 A/F ratio is dangerous by itself sounds like someone who has listened to to much rumor on the honda-tech boards.
I respect your comments spoolin because you usually have great one's to say, but this one seems a little shallow. Hope I am not steping on your toe's spoolin but I don't want some of our other S2000 members to be reading in to your comment like its a post on honda-tech thinking a 12 a/f value is "BAD" and "DANGEROUS".......................you follow?
J. R.
