FMU install help
Old Mar 17, 2010 | 10:03 PM
\\s2kris//'s Avatar
Default FMU install help
I purchased a used comptech kit. The kit had a AEM FPR but no FMU. Can I purchase a 8:1 rise FMU to increase fuel pressure? Wont the FPR regulate the increased pressure from the FMU?
Thanks for your help.
Old Mar 18, 2010 | 02:14 AM
AusS2000's Avatar
The Comptech kit comes with a Rising Rate FPR to replace the stock one. The AEM is just the same as stock so not good for your install.
One of two options:
1) Install a Vortech FMU downstream of your FPR. It will increase your fuel pressure with boost like the Comptech one. I happen to have one for spare BTW.
2) Bigger injectors and some method of tuning like the AEM EMS or Emanage Ultimate.
Old Mar 18, 2010 | 04:31 AM
\\s2kris//'s Avatar
OK, so I should replace the AEM FPR with the OEM and install the vortech FMU to increase the fuel pressure. Does the OEM fuel presure regulator need to be drilled out?
Old Mar 18, 2010 | 12:20 PM
s2000Junky's Avatar
I'd go with the Comptech FPR. (Specifically for an Ap2). They are a nice improvement over the VT ones. Being able to externally adjust the fuel pressure delivery is a huge bonus for tuning, really a necessity that the VT ones don't have.
No you do not drill it out, you simply unbolt it from your fuel rail. You will not use this in junction with the VT or CT fpr.
Old Mar 18, 2010 | 02:05 PM
\\s2kris//'s Avatar
I decided to go with this unit,
http://www.hondamarketplace.com/showthread...3&highlight=fmu
its a FPR and FMU in one. It bolts up to the fuel rail where the stock FPR mounts. You can adjust idle fuel pressure and the rising rate ratio from 1:1 up to 12:1.
Old Mar 18, 2010 | 02:28 PM
AusS2000's Avatar
Looks nice.
Old Mar 18, 2010 | 03:48 PM
s2k aok's Avatar
good find.
Old Mar 18, 2010 | 07:24 PM
s2000Junky's Avatar
Cool, I always prefer more adjustability options
As long as you understand what you are adjusting
s2kbtos
Sep 14, 2012 08:19 PM
Headchef
May 16, 2007 03:00 PM
duff0000
Feb 3, 2007 01:44 PM
markS2kcU
Oct 16, 2005 05:17 PM
