Fuel pressure
Originally Posted by camuman,May 17 2010, 05:12 PM
if this was your first s2k clutch, make sure that bitch slave cyl is bled. i had to gravity bleed it so much to get it to work right. then make sure your pedal/slave/rod is adjusted right.
Yea so reading this everyone saying you cant hit 400 hp on log blah blah i hit 397 on 10 psi on my log you will be fine at 14 psi you should be at 450 with that turbo and that set up. Good luck with everything and dont run it without a tune dont boost anyways you WILL break shit.
Originally Posted by ueat1023,May 22 2010, 08:49 PM
What are you running Aem base tune?\
Walbro installed or injectors
ok guys, so my appointment is june 30th. Since i have a whole month of nothing to do and extra money to save up, should i just get an inline pro 3mm headgasket and install it before the tune?
