Fuel pressure
I don't think your gonna hit 500hp with out either a 3mm or a meth kit. Your are using a higher reading dyno which will help. He will not be able to turn the boost up past 12- 14psi. If money is a problem I would just tune it as is. Have fun with it, when you get the itch for more get a meth kit or a 3mm and get around 50-75 more hp out of it. I think you should make low 400's on a dynopack. Good luck I really want to see how quick that turbo spools up.
Originally Posted by JoeyBalls,May 26 2010, 08:55 AM
I would do the HG, mostly because that is what Evans recommends, also SpecOps hit 500 on a log, with 3mm HG.........
Originally Posted by camuman,May 26 2010, 12:24 PM
the turbo and mani will hold you back the most. i say low mid 4's on pump and close to 500 on race gas.
cant wait to see what evans can do with it.
Originally Posted by JuicedS2K,May 26 2010, 03:29 PM
are you including the 3mm headgasket with those #'s?
log mani is less efficient, so your not gonna get max potential outa that snail.
https://www.s2ki.com/forums/index.ph...ic=670166&st=0
dsddcd has a very nice log setup and this is what he hit.
i think your gonna be slightly under his numbers do to a smaller turbo.
thats not bad at all though, its sick power!
Those little 5857's can be pushed pretty hard. The next step would be to get a better manifold/downpipe.
You going to run a meth injection kit? I would definitely recommend being in NJ (lack of E85 availability).
