Fuel pressure
Old May 26, 2010 | 01:22 PM
  #61
Revenge's Avatar
Does pushing a small turbo harder make them wear out faster than using a larger turbo and it working less hard to achive the same result?
Old May 26, 2010 | 01:33 PM
  #62
Spec_Ops2087's Avatar
With water cooled ball bearing turbos of today, they should outlast the entire CAR'S life regardless of size and "work" performed...
Old May 26, 2010 | 01:34 PM
  #63
Originally Posted by JuicedS2K,May 26 2010, 03:49 PM
I just want to pull on 600cc bikes thats all lol, hoping 500whp is enough.
doubtful, maybe at 100+ even then, 500+ hp is very powerful...be careful, might want to adjust your attitude a little bit. The s2000 is 100% unforgiving so always respect the car (let alone with 2.5 times the power then stock).
Old Jun 29, 2010 | 04:50 AM
  #64
JuicedS2K's Avatar
1 day
Old Jun 29, 2010 | 05:26 AM
  #65
JoeyBalls's Avatar
Good Luck brotha
Old Jun 30, 2010 | 04:30 AM
  #66
spectacle's Avatar
In for results...
Old Jun 30, 2010 | 05:16 AM
  #67
Revenge's Avatar
I think today is the day!
Old Jun 30, 2010 | 05:37 AM
  #68
dsddcd's Avatar
Whats the news?
Old Jun 30, 2010 | 02:53 PM
  #69
JoeyBalls's Avatar
whats the word?
Old Jun 30, 2010 | 05:44 PM
  #70
JuicedS2K's Avatar
Well, not happy.
The car was not holding fuel pressure, it would just completely take a dump after 5k rpm. It was only making 200 whp on 70% duty cycle. pump was making weird noise (walbro 255) so we replaced it, still did not fix problem and new one made same noise. Tested voltage and it was only seeing 10 volts. Clamped the fuel pump directly to battery and it saw 13 volts, fixed the problem but still not holding enough pressure. Jeff said he said the injectors to 90% duty cycle and the car was only making 350 wheel at 14psi. So thats what it made. Now i have to figure out why the hell my fuel pump is making the high pitched noise. I know they are supposed to be loud but this thing sounds like its crying.
