fuel pressure problem?
Old Dec 22, 2012 | 03:29 PM
bois2k's Avatar
I don't really know my way around the aem and they already fixed the ems had just got it back sensors seem to be plugged in correctly what else would cause a car to just die after trying to give it gas?
Old Dec 23, 2012 | 10:47 AM
o'malley_808's Avatar
Do you have an older version of your tune you can try? Maybe your file you keep uploading is corrupted. Worth a shot if you have another map you can try at least to see if you can get it to do more than idle...
Old Dec 23, 2012 | 11:36 AM
bois2k's Avatar
No I don't just have my c16 tune and 91 tune :/
Old Dec 23, 2012 | 11:43 AM
Do you know how to build a quick tune to start the car? post up your setup im sure someone has something similar then can send you to try
Old Dec 23, 2012 | 11:46 AM
wadzii's Avatar
Banned
Have you tried both tunes? The c16 tune will be drivable on pump gas.
Sounds like you may need to get the car to a tuner
Old Dec 23, 2012 | 12:04 PM
bois2k's Avatar
Ok I will try my race gas tune and my setup is low compression 9:1 inline pro stage two with I'd 1000
Old Dec 23, 2012 | 12:09 PM
Yeah Wadzill is right you should be able to see if you still have the issue with the c16 tune just dont drive it only do your off idle test like you were saying before.
This will at least eliminate an issue with the tune/aem
Old Dec 23, 2012 | 12:13 PM
wadzii's Avatar
Banned
You can drive on the c16 tune.. Just don't hammer on it.. Do it grandma style
Old Dec 23, 2012 | 12:15 PM
bois2k's Avatar
Yeah I understand as long as it revs
Old Dec 23, 2012 | 12:51 PM
bois2k's Avatar
Uploaded c16 map did the same thing I took a small video of how I uploaded it if anyone wants to see it throw me you're email
