Fuel pressure regulator needed?
Will I need a fpr if I install my grams 320lph pump with the SOS FUEL pump wiring kit?
2008 club racer
Kraftwerks v2 kit getting ready to install.
2008 club racer
The 2008 has a returnless fuel system so you can't just add a fuel pressure regulator. SoS does sell a new bypass valve that mounts next to the fuel pump in the tank that that boosts fuel pressure by around 3 psi. It is just a different part number Denso piece. I used it and it did raise fuel pressure, but I didn't have any way to measure how much. I think the OEM fuel pressure will be fine for your Kraftwerks kit.
