Fuel pressure regulator needed?
Old Dec 1, 2015 | 04:32 AM
jetguy's Avatar
Default Fuel pressure regulator needed?
Will I need a fpr if I install my grams 320lph pump with the SOS FUEL pump wiring kit?
2008 club racer
Kraftwerks v2 kit getting ready to install.
Old Dec 1, 2015 | 06:42 AM
baZurk's Avatar
Not unless you plan to raise your fuel pressure.
Old Dec 1, 2015 | 06:48 AM
King Tut's Avatar
The 2008 has a returnless fuel system so you can't just add a fuel pressure regulator. SoS does sell a new bypass valve that mounts next to the fuel pump in the tank that that boosts fuel pressure by around 3 psi. It is just a different part number Denso piece. I used it and it did raise fuel pressure, but I didn't have any way to measure how much. I think the OEM fuel pressure will be fine for your Kraftwerks kit.
Old Dec 2, 2015 | 04:15 AM
cuci591's Avatar
I ran 500hp with the stock fpr.
lopez14
Mar 21, 2013 08:00 AM
mrfast32
Apr 3, 2008 04:49 PM
adam_gipson
Aug 19, 2005 12:00 PM
