fuel pump problem
Old Mar 6, 2009 | 09:22 AM
spectacle's Avatar
Check the fuses
Old Mar 6, 2009 | 12:36 PM
scottieboy561's Avatar
all the wires seem tight i pluged unplugged and tightened all the ems wires. i looked in the fuse box and couldnt find one for the fuel pump is there one? next im going to pull the fuel pump and see if the power and ground wires for it are good any other suggetions.
Old Mar 6, 2009 | 12:47 PM
devs2k's Avatar
you checked both fuse boxes? 1 near battery and 1 driver side kick panel
i think the fuel pump fuse is behind the kick panel, IIRC...
Old Mar 6, 2009 | 02:02 PM
DeadZero's Avatar
Originally Posted by Sideways,Mar 6 2009, 09:48 AM
Loose wire.
x2
Old Mar 6, 2009 | 02:06 PM
cheaked all the wires by the ems and the fuse and all is good. went to look at the pump and on top of the pump the 2 rubber hose thingys werent connected. could that be my problem??
Old Mar 6, 2009 | 03:19 PM
Sellout's Avatar
Can you elaborate? What are the "hose thingys" and where does it look like they're supposed to be connected.
Old Mar 7, 2009 | 11:11 AM
sorry but those hoses on top of the fuel pump where supposed to be screwed down so they were loose. the screws were gone so for now i zip tied them together so they couldnt vibrate problem solved thanks for the help
boostedap1s2
Jun 17, 2018 09:55 PM
Prokaw875
Jun 13, 2013 02:39 PM
TonysMI4
Aug 29, 2011 10:10 AM
Spec_Ops2087
May 18, 2010 01:58 PM
ekoms31
Mar 28, 2010 08:21 PM
