Fuel Pump Wiring Question
Old May 20, 2010 | 10:38 AM
  #21
Ek_Jak's Avatar
awesome, thanks guys!
Old May 25, 2010 | 11:32 PM
  #22
Ek_Jak's Avatar
k i just tried to wire it up like the diagram but i think i might have messed up somewhere cause its not working haha..
1. i got the power wire from the battery straight to the bottom relay as stated.
2. the wire goin to the top connection point of the relay is going straight to a spliced wire of the yellow and green wire off of the plug.
3. the left side of the relay is connected to the yellow and green wire i spliced but is connected to the one going to the ecu im guessing.
4. i have the ground spliced and routed from the relay to the plug and a ground spot off the chassis.
im sure i got some mistakes.. help? i sucks i wiring haha
Old May 26, 2010 | 09:31 AM
  #23
S2Kme's Avatar
Originally Posted by S2Kme,May 19 2010, 09:32 PM
Only cut the big yellow/green wire. The black is a signal ground, not chassis ground. I was mislead by the above diagram. Do not cut this wire.
Standard 5 pin relay: #30 - 10ga fused wire to battery, #85 - ground to chassis, #86 - ylw/grn wire from ecu (other half of cut ylw/grn wire), #87 - connects to fuel pump (other half of cut ylw/grn wire). #87a not used. Hope that helps.
^^hey jack, i ran into that problem too but is fixed now and works great. this is how mine is wired
Old May 26, 2010 | 01:57 PM
  #24
Ek_Jak's Avatar
Never mind! my dumbass bought a electronic flasher instead of a relay... hahaha i got it all workin now
Old May 26, 2010 | 06:44 PM
  #25
S2Kme's Avatar
ha yea that wont work.
Old Sep 13, 2010 | 12:49 PM
  #26
wait4vtec's Avatar
what kind of relay should be bought to do this to my fuel pump?
Old Sep 13, 2010 | 05:06 PM
  #27
1SlowSi's Avatar
Bosch / Tyco relay
Old Sep 14, 2010 | 04:56 AM
  #28
wait4vtec's Avatar
what amp inline fuse should i use as well?
Old Sep 14, 2010 | 07:51 AM
  #29
SgtB's Avatar
What size is the wire? That dictates what fuse you need.
Old Sep 14, 2010 | 09:08 AM
  #30
wait4vtec's Avatar
I'm going with 10g
