Fuel Pumps not priming
Old Oct 24, 2015 | 02:25 PM
liquidgsr's Avatar
Default Fuel Pumps not priming
Okay so I finally picked up a engine to after mine blew years ago. I haven't touched the car in over a year and I think I remember that the fuel pumps primed when I turned the key even without a engine. I recently tried it and it wouldn't prime. I have a Full Blown Dual hanger wired up to two relays and a then to the batter. The stock yellow and green wire is where the signal from the factory harness is coming from, and I am not getting anything from it. I wanted to try to fix this before the car went to the shop, but I am having no luck. I have tried plugging in the factory ECU back in to see if that works, but no luck there. Fuse is fine as well. Any ideas.
Cliff Notes:
MY07
AEM V2 ECU with jumper harness for stock ECU
Full Blown Dual Hanger with Dual 340s.
Fuel pumps and relays work when a 12v direct signal is run from battery, doesn't work from factory harness.
Old Jun 2, 2019 | 02:24 PM
Mijae007's Avatar
Cliff Notes:
MY07
@liquidgsr @liquidgyou ever figure this out?
MorngWoodStewie
Jul 30, 2018 10:16 PM
LiamR
Aug 4, 2017 01:19 AM
jsenclosure
Apr 2, 2013 03:19 AM
EK9MAX
Sep 19, 2010 04:19 PM
