Fuel Question
Old Mar 10, 2010 | 05:21 PM
1point3_to_2point2's Avatar
Default Fuel Question
If I picked up this kit if I wanted low power gains would I NEED injectors and fuel pump
http://cgi.ebay.com/ebaymotors/GODSPEED-HO...=item2eab23a509
Old Mar 10, 2010 | 05:27 PM
*JG*'s Avatar
you would still want to have a 255 walboro atleast. Also some smaller injectors will suffice. Forced induction is always going to need more fuel whether you're adding a little boost or alot
Old Mar 10, 2010 | 05:28 PM
so no on stock injectors
i can order that fuel pump
Old Mar 10, 2010 | 05:33 PM
*JG*'s Avatar
No i wouldn't try to run it on stock injectors.You might be ok with running some 440cc injectors. yeah you can order the 255 walbro from just about anywhere that sells pumps. probably get it cheap from ebay.
Old Mar 10, 2010 | 05:38 PM
ill just get some 550s
Old Mar 10, 2010 | 05:41 PM
*JG*'s Avatar
How much boost do you plan on running?
Old Mar 10, 2010 | 05:49 PM
Old Mar 11, 2010 | 07:32 AM
2big4aS2000's Avatar
kit is junk!
weatyGT
May 26, 2014 05:30 PM
Kitesurfer s2000
May 31, 2013 12:30 PM
TerminatioN
Jun 10, 2011 05:06 AM
Redline S2K
May 21, 2011 06:44 AM
cjb80
Nov 13, 2001 09:13 AM
