Fuel Return system needed?
Old Jul 7, 2009 | 08:14 AM
ihiryu's Avatar
Default Fuel Return system needed?
Hey guys,
I'm going to go turbo here pretty soon, waiting on my head gasket and head studs to come in (ordered this morning )!
Anyway, at about what rwhp level is a return system really needed? I've been looking around at fuel rails and it seems like the AP1 is different in design, and the AP2 vs AP2 DBW are different also.
TIA
Steve
Old Jul 7, 2009 | 08:28 AM
JDMallmotorAP1's Avatar
this is the line hose size for fuel delivery
Up to 499 HP .344
Old Jul 7, 2009 | 08:42 AM
ihiryu's Avatar
well looking at your sig, you have an AP1, so you have a return fuel system. I'm an MY08, so I don't have a fuel return system. So what I'm asking when do I really need to move to a return fuel system.
So if I went with 1000cc injectors, F/IC, and fuel pump, what rwhp should I be safe with?
I know on the 350z, anywhere around the 500rwhp range, return fuel system is needed.
Old Jul 7, 2009 | 08:58 AM
for a high whp car, i would think so... because you want to run 1000cc injectors, also a fuel pump would be needed to compensate for the large injectors. then With all that pressure where would the excess fuel be dump back to? when your injectors open and close.
IMO yes return fuel system would be nice. But then again their are some members on here who has an 08 that are pushing good numbers. so i hope they chim in.
Old Jul 7, 2009 | 09:29 AM
EngineerX's Avatar
The correct answer is: it depends on the pump you select for your application.
Most high capacity pumps require a return line in order to prevent overheating or simply because they don't have built-in relief valves or that's just how they were designed. Pump overheating or cavitation will occur if you use a non-bypass high capacity pump that will be moving alot of volume against a semi-deadhead condition (when fuel volume from pump largely overcomes fuel demand at injectors).
If the pump has a built-in relief valve and has been designed for returnless use, then you don't need a return line.
Target horsepower dictates pump size, so you need to determine if the pump you will be using requires a return line.
Old Jul 7, 2009 | 09:33 AM
stitos2k's Avatar
I'd been wondering about that, great explanation. That's first time I actually understood what someone was talking about on whether or not you needed a return or not.
Old Jul 7, 2009 | 09:40 AM
ihiryu's Avatar
Agreed, that was an awesome explanation! I guess I'll have to do some more searching around. This is the first time I've really messed with a car without a return fuel system. So I'm assuming I couldn't get a plain Jane walboro 255 this time
Old Jul 7, 2009 | 11:09 AM
camuman's Avatar
check this thread out, he did it without converting to return fuel.
https://www.s2ki.com/forums/index.php?showt...&#entry15405385
478whp is pretty nice
Old Jul 7, 2009 | 11:59 AM
EngineerX's Avatar
Walbro 255's have an internal relief valve, so they should work ok returnless.
The only problem I can see could be shortened pump life, because the pump *may* be overworking itself pumping against higher pressure all the time. But it's hard to say how much shorter life. It may even last the same! in other words - who knows
Old Jul 7, 2009 | 01:18 PM
ihiryu's Avatar
I guess I'll have to give it a shot then. I'm going to order the walboro here pretty soon, and that was good link to that build camuman.
JUSTINTHECOASTIE
Aug 9, 2017 10:52 AM
Jaspah
Feb 4, 2017 12:12 PM
dsddcd
Jan 5, 2013 07:40 AM
JoeyBalls
Jan 7, 2011 05:13 AM
cock_diesel
Aug 18, 2007 01:30 PM
