Anybody get fuel starvation on left-hand corners or boosted under half a tank?
. I've designed a plate that easily drops inside the fuel tank covering the fuel bowl eliminating any fuel slosh which causes fuel starvation to your engine.
100% cheap fix. No need for expensive external loud pumps.
To find out more please join Boosted s2000 on FB search fuel plate.
Looks like a good idea for fuel slosh, although that's only half the problem. The refill slots at the bottom of the bowl, which is a major problem for big power guys aren't large enough to supply fuel fast enough to the fuel bowl if below a half a tank. The pumps draw too much fuel too fast.
That's easy the slot can be easily made bigger using a large flat screwdriver.
I've thought about trying to get my tin snips in there and try to trim the slots out larger. I'd use a dremel and grinding tip but excess fumes and all..... LOL
I have a Radium surge tank which has two pumps (staged) mounted inside of it so you barely hear them except when priming. After my original response, I realized that you have to fold your piece to get it into that tank. Good luck.
