Fuel station solved.Drop in fuel plate.
Old Dec 11, 2018 | 11:21 AM
soulicious's Avatar
Well, you get what you pay for I guess. Okay, I'm done.
Old Dec 11, 2018 | 01:37 PM
Kitesurfer s2000's Avatar
Originally Posted by s2000ellier
also should be 20$ not several hundred for an external fuel pump
Whatever you're on can i have some please
Old Dec 11, 2018 | 02:31 PM
s2000ellier's Avatar
I meant the plate is the cheap solution not spending hundreds on an external fuel pump
Old Dec 11, 2018 | 03:11 PM
soulicious's Avatar
I want some too, j/k. For the surge tank setup (Radium anyways), it would be more than hundreds. I think I spent at least $800, but that's with PTFE hose and fittings for feed and return lines. It's expensive, but well worth it in my opinion for my setup. I don't have any fuel starvation issues even WOT driving on near empty straight line or in the twisties. The plate would be a good cheap solution if it works as expected.
Old Dec 11, 2018 | 07:35 PM
Yes for 99% of people that are running under let's say 800/1000 HP the plate is a amazing cheap option.If you have stupid hp and can drain the fuel bowl in one pull drag racing than that's the only exception .
Old Jan 16, 2019 | 02:35 PM
Timmigrant's Avatar
Call me crazy but I've found fuel starvation to be sensitive to suspension spring rate. I was using 10k springs on a set of Tein's and never had any fuel starve. Running on RE71R tires I almost ran out of fuel on the track / autocross and never had any starvation issues. I upgraded to some KW V3s with 8k springs, same alignment settings and same tires. I was fuel starving at the same track running the same lap times with anything less than 1/2 a tank of fuel. Same thing at autocross. With the 8k springs I was having to fill up the car multiple times a track day, and run at autocross on a full tank. After working through a number of other possible causes the only thing left was the change in spring rate. I got some stiffer 10.7k springs for the KW V3s and my fuel starve issues were gone. I'm now supercharged with 400 ish whp and had no fuel starve problems at the track. So long story short, the roll of the car has a dramatic impact on fuel impact as well as the tank design. Stickier tires will induce more roll.
Old Jan 17, 2019 | 08:28 AM
flanders's Avatar
I got my plate from Kitesurfer a while ago, fitment was spot on and very easy to install.
Just waiting for winter to pass then it will be track tested
Old Jan 17, 2019 | 09:26 AM
s2000Junky's Avatar
Great to hear. Will expect no issues with mine that's coming.
Old Jan 17, 2019 | 10:46 AM
Originally Posted by 5thgen
To be fair, he documented his plate over 3 years ago. So to say its exactly the same as yours seems a bit much.
I was Boosted in 2009 when I first had the problem.
Tuner at time said you need to stop the fuel jumping out the bowl .So in fact he gave me the idear because having loud external pumps was not a option.
I'm 22psi gen 2 gtx3582r
My exhaust is quieter than standard.
My clutch is a hybrid friction one side 6 puck the other lighter than stock with stock drivability.
Saving money for everyone was the main goal .
The first plate I made by hand around 2011 kept getting in the way of the fuel float .
I then got married and went through a terrible divorce .Car sitting for 4 years .
2016 Google started saving searches I was looking for a fuel tank to cut open which came up on eBay result .
So in early 2017 I started selling hand made plate's and they are working win win .
Unfortunately life gets in the way of your dreams but the S will always be with me.
Sorry for the essay I've been off work for 7 weeks with a bad back and high on diazepam .
Old Jan 17, 2019 | 11:04 AM
Road racer's Avatar
[left]Turns out that Kitesurfer and I were lost twins separated at birth. This fuel plate cover idea brought us back together.
