Fuel system
Old May 21, 2019 | 12:32 PM
2004TurboS's Avatar
Default Fuel system
Is anyone running an inline fuel filter with e85?
Also so I’m trying to figure out the best option for upgrading the factory lines.
-8an feed with stock feed as return or -10an feed and -8an return ?
Old May 23, 2019 | 02:58 PM
gotembro's Avatar
Do you need to do upgrade lines to run E85?
Old May 23, 2019 | 03:48 PM
Charper732's Avatar
Im running -6 off the stock hard line, which is the same size as a -6. The rubber hose with that banjo is the restriction. Everyone says run -8, not sure why though. I'm running -6 making 600hp and I think stewart is running -6 aswell making like 1000hp.
Old May 24, 2019 | 06:01 AM
hatrickstu's Avatar
You will basically never need larger than a -06. I am making 1,000 on a single -06 and E90. For a filter, this is your best option on the market:
ID F750 Fuel Filter - Injector Dynamics
Old May 24, 2019 | 06:03 AM
hatrickstu's Avatar
The only real reason you need lines (for most builds) is if you are changing the pump hanger since they aren't going to adapt to stock hard lines.
Old May 24, 2019 | 03:17 PM
riceball777's Avatar
No
I have been making over 600whp on e85 on stock lines forever. Just got a walbro in take 450 pump and Id 1300cc injectors.
Spoolin
Sep 28, 2010 01:08 PM
airwalk07143
Sep 23, 2008 09:13 PM
TelosHedge
Mar 28, 2008 05:34 AM
learnerspermit
Apr 29, 2005 11:57 AM
